Hello.
Yesterday 28Nov2022 i have updated my kernel to 5.15.0-53 (prev version 5.15.0-52). After reboot my device, wifi driver is not detected.
This is my detail device after revert to 5.15.0-52
How to solve my problem when i using kernerl 5.15.0-53?
Thanks
Most often this happens when a network driver was not installed with Dynamic Kernel Module Support (DKMS).
Can you please try:
sudo apt install backport-iwlwifi-dkms
Reboot and test...
Thanks for your response.
When i run that command? When 5.15.0-53(error) or 5.15.0-52?
Please run it on the -53 kernel.
If the -52 kernel is still working, it is an option to lock that kernel in and stay on it if you need to.
thank you for your response
system
Closed
February 28, 2023, 2:05am
6
