Nominatim Installation on Zorin OS 17.3 Pro in a venv
Hi, thank you for OS Zorin
I can't install locally Nominatim (https://nominatim.org/)
for working with geopandas and geopy.
And with geofabrik files (.gfb)
But, the setup.php file is absent.
Thank you for any recommendation on how to install it
in a virtual environment :).
Have a nice day.
José from France.
Have you gone through the installation steps for Ubuntu 22.04? Thats what Zorin 17 is based on.
According to the documentation, there's no configurations for a virtual environment. Instead, they want you to create a seperate account for the service. Since there's quite a bit to install and configure, i won't install this to test it.
All you need to do is to follow the documentation and you should be fine.
https://nominatim.org/release-docs/latest/admin/Install-on-Ubuntu-22/
HI @freshjeff, thank you for your time.
From the beginning, I tried to install, Nominatim in my venv.
I noted this page. I wondered if it was not too complicated
just for using Nominatim from Jupyter Notebook on a PC. Not a server.
I'm looking for a way to return geolocalisation point into adress, town...
in a notebook.
Thank you.
José.
