Not a good day with Zorin Pro
Well, all of a sudden I noticed that my wifi icon is gone from the taskbar and when I try to open wifi from Settings and scan, it doesn't find any devices. Wow, this worked last week, what happened? Guess I can't attach my wifi speakers and they worked fine a few days ago.
And of course, the Software Center quit working again - can't wait for LITE. Hope it's more stable . . . guess I'll shut down for the day . . .
Yep, you are correct. I removed FreeOffice app and in terminal it told me to run apt autoremove to uninstall things that were left behind. Does removing an office app mess with wifi? If it does, then I had no idea . . .
I did read but I guess I missed something. Thanks for the help . . .
I've got a full backup so yes I could put it all back easily. Might just wait for Pro Lite and install it instead. :grinning: :grinning: :grinning: :grinning:
Just did a complete restore and wifi is working correctly again! Software Center is still out to lunch but I figured that. Thanks for the help on this.
There are many threads reporting that the Wifi Icon is vanishing all on its own from the Panel (taskbar).
I'm not sure this is solved, nor necessarily isolated...
I see many people waiting for Zorin Pro XFCE.
That could be a true. Gnome fail. Near a taskbar shortcuts a clock time not working. Not all. Linux Sims things working great and another are problematic or confuse.
