I was trying to install VPN on my OS and I got strange error
when I tried
sudo apt --fix-broken install
then this
sudo apt upgrade
then this
sudo apt install python3.10
and still getting same error
and when I tried this
sudo apt --fix-missing
I got error
Did You tried directly to install the Packages? When I see that right in Your first Screenshot the Command should be:
sudo apt install python3-packaging python3-babel python3-aiohttp python3-openssl
I have take a quick Look in the Terminal and there are all available.
Hm ... Interesting the Terminal shows me that it is available:
Wait: Do you use Zorin 17?
There is also a flathub-version of proton-vpn in the gnome-apps-store.
Maybe that is a workaround for the requirements.
I tried this and got same error
I also tried this and I got error
Open software & update to make sure these sources are enabled
If not, then enable them and run sudo apt update
system
Closed
May 18, 2024, 10:04am
13
