Not usable SSD after failed Installation
Hi, i tried installing Zorin from USB. During install, i chose secure partition. The install failed and left me with a ssd that now cant be used. I cant even repartition the drive. My computer is now unusable. Any suggestions?
You can use the same USB where you have the Zorin OS ISO and boot into the live environment. From there, follow the usual installation procedure, selecting "Erase disk and Install Zorin OS" at the installation type screen:
This would delete the contents of the drive but is the easiest option as the installer would apply all the defaults, which is often the preferred method.
Moderator Note:
I changed the Thread Title to make it more precise related to the Issue.
