Hi, I am in the process of installing Zorin OS on my Lenovo MIIX 320 10ICR with 4GB RAM. Unfortunately, as in:
None of the solutions with me work, as I also have no sound; the microphone does not work and it does not catch the two cameras.
I have absolutely no idea what to do next, I am very green in these matters. I wanted to install Zorin because I was using it on another computer - but there were no problems there.
I would hope for help on how to fix the sound, microphone and cameras.
Can you please create a file in etc/modprobe.d/ to allow for blacklisting a module:
sudo touch /etc/modprobe.d/blacklist-audio.conf
Now, open that in a text editor:
sudo nano /etc/modprobe.d/blacklist-audio.conf
Add the following line: blacklist snd_hmdi_lpe_audio
Tap ctrl+o to overwrite, then the enter key to save current configuration. Tap ctrl+x to exist the editor.
Yes, I have been searching around. I have seen the same one I suggested earlier posted.
And I have seen nothing else that offers an actual solution.
I have seen a lot of posts and comments about Lenovo being extremely resistant to provide for the Open Source drivers.
