NTFS Secondary Hard Drive - Folders Show up as Shortcuts
I am on Zorin OS 18, dual boot Windows 11 and Zorin OS 18.
I have a hard drive (NTFS) that I use as storage drive, accessible from Windows and Zorin OS. I can read/write from both systems, all is working
However, as you can see, 2 folders show up on Zorin OS with a weird icon which makes them look like it's shortcuts, not real folders. They are actually real folders.
I checked solutions in forums, I've already disabled fastboot and it didn't fix the issue.
Interestingly, these are the 2 folders that I sync on Windows with the Proton Drive app. I tried to disable it, it didn't fix the issue.
Any idea of how ti fix this?
Since you are using an NTFS partition format, which is only for Windows, I believe you have to take ownership of your NTFS drive, in order to use it properly.
Its as I said in that thread back in 2021, I really recommend a GPT EXT4 partition filing system, over that of NTFS. But @Aravisian post about taking ownership on NTFS partition filing system is correct.
Thanks I'll try, i assume the drive will remain accessible when in Windows 11?
If formated as ext4, what is the compatibility in windows 11?
Being curious why would some folders work and some others be inaccessible?
It would not be accessible to Windows OS - so if you need it too be, it must be in NTFS format.
Zorin OS can read and write to Ext, BRTFS, ZFS or NTFS.
Windows - NTFS.
