I looked on Help, but no matter what I do the computer (HP ENVY 17.3) refuses to startup my keyboard Numlock even after saying it installed Numlockx. I am new to this can any one help me?
Can you try the selected answer here: https://askubuntu.com/questions/155679/how-to-enable-numlock-at-boot-time-for-login-screen ?
As for installation of numlockx, did you install using Synaptic? If not, then I recommend trying that. If using the terminal, can you verify your installed version using numlockx --version ?
Tried the Synaptic as you suggested, after signing in Numlockx was on, the issues is logging in. On my Linux Mint 20.1 - I can install Numlockx and it works great right from the login menu, however on “Zorin” it doesn’t and thats my issue making it start from log in screen so I can just use my numbers on the keypad with out always going through the hit Num lock key to enable the Num lock key pad from the very start after the computer starts up and ask for the pin. Hopefully I am explaining myself clearly new at this.
Your explanation is clear.
Two more recommendations, if you don’t mind trying them out:
- Can you try dconf-editor (alt+F2 and type
dconf-editorin the box that appears)? If you don’t have it, usesudo apt install dconf-toolsto get it. In the editor search “numlock” and ensure that both results are set to on. - https://askubuntu.com/questions/1161166/how-to-enable-numlock-at-boot-time-for-login-screen-in-ubuntu-18-04
Carmar, finally it accepted the following:
1 Answer
1
Do the following:
xhost +SI:localuser:gdm
sudo su gdm -s /bin/bash
Now, you need to use gsettings or dconf #or dconf-edit if you have it
Go to /org/gnome/settings-daemon/peripherals/keyboard/numlock-state and change it to on
or simply after the two lines do this
dconf write /org/gnome/settings-daemon/peripherals/keyboard/numlock-state "'on'"
or
gsettings set org.gnome.settings-daemon.peripherals.keyboard numlock-state 'on'
Now reboot
Thank you for helping me with this matter much appreciated.
This seemed to work for me at the login screen, and then it turns off again once in the desktop. This is truly a bizarre choice by Gnome devs to make this very normal thing so convoluted to achieve.
Once again, Plasma makes life so much easier with a standard entry in 'settings':
Does anyone know how to KEEP the number lock on/active after login?
EDIT - i found this - seems to work:
gsettings set org.gnome.desktop.peripherals.keyboard remember-numlock-state true
