Is there a Way to fix this, I want my laptop to use both of my GPU's once for smaller activities and another (NVIDIA 1660) For higher processes e.g. video editing and gaming how would I do that?
Which Nvidia driver do yu have installed?
Have you configured usage using Nvidia prime-select (on demand)?
In terminal, you can run
sudo prime-select on-demand
That's it. Done.
And that Command makes that the System automatically switch between iGPU and eGPU?
Yes. The integrated will be used during lower graphical need, conserving power.
On higher demand applications, the Nvidia card will be used.
Good to know. Thank You.
This is not always the case, i have a iGPU (Intel Arc) and a dGPU (Nvidia). But prime on my notebook is not supported. It does interact automatically without any issues.
In linux i can change the setting to which gpu i prefer, but that’s it.
You can reinstall the Driver and check for any physical issues related to your device. Also check if there are any installation errors.
