A couple of problems. I thought I would give it a test run, so ctrl+alt+F3 took me to TTY, but I was asked for a login, which was OK, then it asked for a password, which wasn't OK. I entered the only password I've used but it didn't accept it. When I tried to exit with ctrl+alt+F7, my screen went blank. I had to restart using the pen drive containing the OS.
No, but if I have the USB stick inserted when I restart my screen returns. I don't know why. I am using a fully installed Zorin 16 Pro now with the same resolution problem.
Please post the results here. I want to see exactly what your GPU is. We might have a case of, modern Nvidia driver not work, older driver requires situation.
Since my last reply, I've powered the system down and rebooted without the USB drive. I still have the same problem. Nothing is different. I have no USB drive inserted.
I installed Zorin 16 Pro using the USB and I don't have it plugged in. However, I discovered that, when the screen goes blank to the point I can't recover it, booting with the USB in restores my screen. It doesn't boot from it, though. If you don't understand, imagine what it's like for me... I'm so grateful for this help...
I know, this whole situation is confusing as heck to all of us, were grasping at string at this point. I realize FrenchPress is having no issues, but I am sure she has other hardware that is different, different mobo, different BIOS for example.
Praveen may be running the same kernel as all of us, cause its Zorin OS. However, he is running different hardware, different mobo, different BIOS. And for all we know, that alone could be the issue.
But the last thing I want to do is break this guys machine, so, I won't be recommending BIOS updates at this time, until all other options have been fully exhausted.
