Hello there !
I'm trying to install nvidia drivers but in settings still at "llvmpipe".
My secure boot is disabled, and i installed nvidia driver through Software Updater :
Can someone help me please ? ![]()
Hello there !
@Aravisian advice, you should not go for the tested version as this causes issues. From your screenshot choose the 535 listed further down the list.
@swarfendor437 thanks for your reply, unfortunately i changed to 535 listed further down the list, but still have llvmpipe in graphics
Did you reboot the machine after installing the drivers?
Yes i rebooted my machine
I assume you are on ZorinOS 17.1 Core.
Which Nvidia graphics card do you have?
@zabadabadoo I have an RTX 4070
Have you tried the
550 (proprietary)?
Yes, same problem
Please launch terminal and run:
sudo apt remove --purge '^nvidia-.*'
Then
sudo apt install nvidia-driver-550
It will take some time. Once complete, run:
sudo add-apt-repository ppa:ubuntu-x-swat/updates
Watch for any errors. IF you see any, relay them in thread. Otherwise, Reboot the computer fully and test
nvidia-smi
@Aravisian thanks for your reply, I solved my problem by selecting the driver "NVIDIA driver metapackage from nvidia-driver-550 (proprietary)" ![]()
