I installed Zorin OS recently and my graphic card RTX 3070 Laptop is not detected and I have instead this weird name detected: NVIDIA 01:00.0 NVIDIA Corporation Device 249d (Neofetch)
I installed the last Nvidia driver suggested by Zorin (535.113.01), tried a few ulterior driver version, even reinstalled the OS a few times, but my graphic card is just not detected, I tried several solution found in the web and nothing work
I'm a new linux user so I don't know how this really work and where to search to fix this issue, so I hope there is someone who can help me, thank !
You may also try using the 525 driver as there has been a few issues with the 535. You could attempt the 535 after another update is posted or a newer version (536/7) is released.
Is your issue that the card is not Detected (and not being used) or that the name does not show up in the way that you expect?
In your O.P., it shows the Nvidia card as detected.
Some users seem confused, when coming from Windows, to see their hard drive listed as /dev/sda instead of as >C:
This does not meean that their drive is not detected. Can you please clarify this?
Tap alt+F2 and enter in nvidia-settings and see if your Nvidia configuration settings window pops up.
no that's not the issue, in the first place I wanted to correctly install the drivers because my wacom display is directly connected to my graphic card, but my wacom screen just does not show up (before to make all this change, the wacom display was detected by gnome, but I was unable to use it)
when I start it from the terminal
ERROR: A query to find an object was unsuccessful
ERROR: Unable to load info from any available system
(nvidia-settings:8175): GLib-GObject-CRITICAL **: 12:45:07.863: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:8175): WARNING **: 12:45:07.864: PRIME: Failed to execute child process “/usr/bin/prime-supported” (No such file or directory)
** Message: 12:45:07.864: PRIME: is it supported? no
I did all the command and update you said me to do, but literally nothing change, is even worse because my computer detect only one graphic card now
before :
now :
edit:
when I made the command sudo ubuntu-drivers install my screen just blank black and I waited like 1 hour before to force manual reboot
You might take photos of your BIOS and relay them here... Other than that, I am not able to be familiar with your BIOS Settings enough to be very much help on finding or adjusting settings.
Hybrid Graphics are a BIOS setting. It cannot be disabled from with Zorin OS.
Everyone's bios is different, even in the same manufacturer. This is because of physical hardware configuration. We really would need to see images of your bios in order to assist in its configuration.
