Cannot access /mnt/boot permission denied. And the same for/efi
Could that be because itās trying to do it in the live usb instead of the Zorin partition? Should I do it in /dev/etc instead?
LS - except lowercase...
Ugh... need sudo
sudo ls /mnt/boot
sudo ls /mnt/boot/efi
Done
Now what? Try to boot into Zorin from the grub menu (with the acpi=off spec_store_bypass_disable and i915.whatever=*?
Iāll give it a try.
The above process was to determine whether or not you had Zorin OS installed as EFI boot...
So what should I done t?
Sorry do next (I hate spellcheckers)
In your BIOS; did you check if you are set to MBR or EFI?
In the LiveUSB, did you determine if the Zorin Install on disk has /boot/EFI and that the EFI directory is not empty?
It has it but itās empty
Yes efi
If that directory is empty, that leaves us uncertain. It may mean that Zorin OS was installed as MBR... Or it may mean that the EFI partition (The ESP), being unmounted, is not being displayed in that directory.
So, our goal here is to figure out why a black screen - we considered it possible that you had a split MBR/EFI install going on since installing as MBR was a suggestion made earlier.
Do you remember explicitly changing BIOS and installing as MBR?
I got rid of the black screen with the acpi=off spec_store_bypass_disable i915.force_probe=* commands but that led to the āhave to mount kernel firstā error.
No I never changed anything to MBR
Really?
Man... I was chasing after that like a dog after a car...
Well. Good news...
And it helped you explore some essentials.
The efi partition is p1 where windows boot is. I made another efi partition at p6 in case I needed it and have tried telling install to use both of them at different times without solving the NVram problem. I got the boot menu to show up by doing a bcd edit using instructions from Ubuntu forum.
But I still get the error about kernel though maybe Iāll try agai after the changes tonight. Concerned that boot efi is empty though. I
Iām going to have to go out in about 30 mins - menās night at church.
Can try the boot menu one more time but concerned that boot efi is empty.
You should only have one EFI partition. This may actually be part of the problem...
I recommend consolidating to one. We can create a walkthrough on this when you are ready.
I can get rid of it in disks
Iāll try again in the morning and thanks so much for all your help over past week
Thought I could get rid of it in disks but doesnāt have the ability to revert it to free space. I could probably make it something other than efi - FAT for example. I do know I can make it free space and add the remainder on to the Zorin partition in the install process so that might be the way to go while trying another install. May still error out at the grub install fail point but could be enough done to allow booting from the menu that I manually installed earlier in the week. Still concerned that the squashfs isnāt going to be in the right place. Is it supposed to be in the Zorin partition? Or in the efi partition? Efi is probably too small so I assume the Zorin one. Is there somewhere I can copy it from? Should it go in the boot/efi folder? It should be on the usb stick but that is a iso file in ventoy. Is it the squashfs.mod file that was read only in the little loop drive when I was running usb live?
