On My Laptop-with Zorin 17.3-When i plug in my mouse- sometimes it didn't move but left and right click work
Hello :smiley: as in title: when I plugin in my Mouse to latpop(when I want play game) - mouse don't move but left and right click work- but sometumes work
Before first time this situacion-i normally plug in my mouse an work and maybe when i shut down my laptop in plug in moise-and when he off-I plug off mouse-maybe this is source? I don't know but this is little flustrating when I forgot plug off my mouse before sthud down my laptop and nex day I turn on-mouse don't move...
When I(maybe) turn on my laptop without plug in mouse-and turn off-when work(maybe I don't know why sometimes work xD)
My laptop is ASUS LOQ with AMD RYZEN and NVIDIA Geforce 5030
Mouse acteleracion is on
Hello,
Do you have dual boot?
If no, disable Secure boot from your Bios.
If yes, disable fast startup in Windows power settings
Are you on Wayland or Xorg ? in terminal run
echo $XDG_SESSION_TYPE
If it's Wayland switch to Xorg:
  • Logout
  • At the login screen, click your username (don't enter password)
  • Click the gear icon in the bottom right
  • Select "Zorin Desktop on Xorg"
  • Log in
Did You checked in BIOS if there are any USB Energy Saving Stuff is enabled?
I check and secure boot of and I switch on xorg and sitll nothi-when a return to wayland was at the moment than touchpad not workin 0.0 but for redtar-he working :D(when toucpad not workin mouse the same-not working)
I don't see any option woth this-How these iption would will be?
Unfortunately there aren't unified Setup's for this. And of Course Your BIOS doesn't have to have this Option. But some have the Energy Saving Options where the USB Port goes in some kind of Sleep Mode. Maybe look if You find Settings for USB Ports.
AAAA i See-right i have battery mode to rest-ok I check :smiley:
I was chekt and I don't see any option which could something doing with usb...
My laptop shut down hard when I play in minecraft on them-and I begin thing is something was broken? I see in kernerl log than something fragment memory not loaded and i don't understand this brcause nex fragment is loaded and i don't know x)
Is soirce then my mous don't move is this than laptop workin 10h (he mustnconnect to power because without this-just batterry-work 1-2h)in game, battery going tonlow and shut down or beiging to sleep mode-is these things maybe broken something in kernel?
How I can chack is somethign is broken in sysmwt even evrywthing work normally?
Can You post the Log Entry?
Actually no-my laptop rest because I see tha a little force them x)
I want ask abput this usb setting:
I aks Lumo AI and he recomendet this option:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend=-1"
This will ok?
When laptop's battery will 0% and I on calm to 100%-i send kernl.log
And about my power seting:
Forst i have balanced form mode than if Bayerry is low-switch for battery redt mode
After I switch to fast baterry mod(i don't word in english:"wydajność") and still nothing
I check my kern.log and I don't find this line-and I don't wnat send all because In lernel log is my adress mac and I don't know is send this to internet is securir xD
But I plug in my mouse and kernel see this mouse-when I plug off-and again plug in-i find then kernel device descritpion read/65 error -71 but whhen I connet to power-again see thsi bit mouse dont move x)
I check my mouse on computer and...on my computer not working(like laptop)-and even shut down my computer(without mouse computer in ranom moment not shut down)
Could be worth a Try.
Ok :smiley: I try :smiley:
But I chekc my mouse and I have streng situacion then my mouse-very low loght when laptopn don't plug in to my laptop and when I connetc pwoer-light normally...I don't udnerstand why this happend
Ok I change and still-how before mouse don't move
I forgot wrote than my mouse is GTX 165 Trust
Do You have another Mouse what You could test to double-check the Behavior?
Unfortunally- no :c
What's mean?
Is in my laptop is possible adding on touchpad right click with left click?
