One more topic about : monitor won't wake up
Hello,
I'm running Zorin OS 18 Core on a mini computer : GMKtec NucBox_G10
My graphic card is : AMD Radeon™ Vega Mobile Gfx
As you got it from the title, when I set my computer on sleep mode, I can't get the monitor to wake up, only the computer wakes up ( as I can infer from the glow of the power button : it stops flickering when I press the power button )
I've already done some research on the forum, I've tried a few things, including the BIOS settings : nothing worked.
In particular, I've tried to type xset -dpms in a terminal.
I've deactivated secure boot, etc... I've done several things I found on the forum.
This problem is really annoying...
I haven't tried to modify the kernel ( pretty afraid of that ).
Do you have an idea what I could try ? :slight_smile:
Thank you in advance : I like Zorin OS a lot, but that problem is ruining everything :frowning:
By the way : I got that info :
produit: Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
fabricant: Advanced Micro Devices, Inc. [AMD/ATI]
identifiant matériel: 0
information bus: pci@0000:05:00.0
nom logique: /dev/fb0
version: 71
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm pciexpress msi msix vga_controller bus_master cap_lis
and about kernel :
6.8.0-100-generic
And I forgot to say that it works fine with Windows 11.
Does this mean, that Windows is still installed? If yes: Is Fast start-Up in Windows disabled?
Did You installed the Kernel because the nwer one didn't worked on Your Machine?
Does Your System run in Wayland or X11? You can check that with the Terminal Command echo $XDG_SESSION_TYPE
When it runs in Wayland, You could try it with switching to X11/Xorg. To do that, go to the Login Screen. Click there on Your Profile so that the Passsword Field appears. When it is appeared, You should see a Gear Icon in the bottom right Corner. Click on it and choose Zorin Desktop on Xorg''. Then log in.
Hi, thank you for your answer.
it returned X11 but it was Wayland before, I've tried to change for Xorg ( it displays X11 as a result ), but it didn't work.
Sorry I didn't understand ; I've tried to update Grub but I'm afraid of modifying Kernel... Maybe I've modified it without knowing ?
I forgot to say I have dual boot windows 11 / Zorin, one disk ( 256 Go ) each, and it boots on Zorin as first choice.
When You want Xorg, X11 is the right Output. It belongs together.
Do You remember what You have done? Because the 6.8 Kernel is an older one. Currently, there would be 6.14 and the newst 6.17 on Zorin 18. Do You have now a displaying GRUB Menu at Start-up?
Then, some Questions:
  • Is Fast Start-Up in Windows disabled?
  • Is Your BIOS in UEFI or Legacy Mode?
  • What Tool did You use to create the Bootstick?
FYI. Z17.3 is using kernel 6.8.
But the User wrote:
That was the Reason why I asked.
I've reinstalled Zorin OS 18 and now the kernel is : 6.17.0-14-generic, but the problem remains.
( I will answer your previous questions soon )
It seems the problem ( monitor won't wake up after computer being set to sleep mode ) was coming from the AMD Radeon graphic card, because I received my new GMKtec mini computer today and it works fine : I don't have the same problem I had with AMD ; the new one has an Intel processor and graphic unit, it will wake up just fine.
So, now, I will send back the AMD computer and ask for refund.
This is the answer I got from the GMKtec support :
" Try using the "shallow sleep" (s2idle) mode instead of the "deep sleep" mode.
To set this mode:
Open a terminal and edit the GRUB configuration: sudo nano /etc/default/grub
Locate GRUB_CMDLINE_LINUX_DEFAULT "quiet splash".
Add mem_sleep_default=s2idle within the quotes, making it look like this:
`GRUB_CMDLINE_LINUX_DEFAULT="quiet splash mem_sleep_default=s2idle"``
Save (in the nano editor, press Ctrl+O, Enter, Ctrl+X).
Update GRUB: sudo update-grub Reboot and test sleep mode.
If the above steps are ineffective, it is recommended that you switch to a Windows system.
Thanks for your patience and cooperation.
Warm regards,
Lara
GMKtec Customer Support Team"
I hope it will help someone.
edit : the monitor will wake up, now, but the computer is NOT in sleep mode, it won't "stop running", so... That's not exactly what I want, this is not sleep mode.
The instructions ask your to apply S2Idle, rather than S3 - deep sleep.
So it is a "sleep" state, but a shallow one.
What this shows is that the ACPI firmware is likely incomplete and the recommendation they gave to use S2IDLE demonstrates that they know that it is.
Second possibility is that the firmware does not actually fully support S3 deep sleep - but this also would mean that they are aware that it does not.
