I find this interesting as some of these are concerns that users have raised here on this forum.
Such as: Will Zorin OS 17 have Firefox as a Snap Package only?
The author says:
If you are an Ubuntu user, I recommend waiting at least 3 months before you upgrade so most of the bugs get fixed.
This really is a strong statement about how users seem to feel eager to rush to the latest. Waiting on Zorin OS 17 based on Ubuntu 22.04 sounds like Zorin OS 17 will be far more stable than the release of Ubuntu 22.04 was.
Now, I have seen quite a few poor reviews. This one is just the most heavy handed in its wording.
Others focused more on LibAdwaita and other grievances.
But one thing I take away from it is: ZorinGroup should feel free to take their time in development. It looks like there is a lot of sweeping up and mopping on this one.
I believe that is one of the reasons that the Zorin's take their time with their releases. It allows Ubuntu Devs to fix what they broke, if not fixing it for them, allowing Zorin devs to release a more stable and efficient OS.
You can actually compare Ubuntu LTS releases and Zorin releases and see where sometimes, the Zorin's actually do fix Ubuntu issues prior to canonical. The responsiveness is also more improved in Zorin. Anyone that compares the two will notice the difference that Zorin's customizations lend to the base.
I would really like to see what they would do from scratch!
Actually the image nane refers to ZoninOS 8. I even had to go and check the date of that ZDNET article when I saw that.
Z16 screenshot does appear later though.
We don't want unwarranted comments that ZorinOS appears dated because of that screenshot image. But I guess it could now inspire some Z8 retro looking desktop customisations of Z16.
Yes, there are some issues with Ubuntu. When I went through my Ubuntu phase earlier this year with Ubuntu 22.04 there were some things I really liked, and disliked. The 2nd thing I did after install, update then 'De-Snap'.
But if not for that experience I never would have learned about gnome shell extension manager, removing snaps, Gnome Circle and Flathub store...
But there were some things I did like about it too to be fair. After 3 months or so wiped it out with a fresh install of Mint XFCE...
The sad truth, Canonical has meddled with Ubuntu too much...
The disadvantage of rolling release is that the release itself becomes the objective IMO. In other words, unnecessary updates are made to maintain the developer's authority.
Linux Mint works perfect, Ubuntu 22.04 and 23.04 has bugs and not stable enough for using a daily driver. Pop OS is also stable and works fine.
The problem basing your product from another product is if you have issues unless you fix them yourself and try to contribute to upstream it is almost going to suffer the same issues until the base is fixed by other devs.
Debian 12 works a treat and so does the new version of MX linux. I also don't have any issues with fedora currently. If I can't find a package in the repo for it I use a flatpack but I've always been using the method of how I get my software as repo > deb/rpm file > flatpack > appimage > snap in the form of what I use on my systems.
