Open Core and Zorin problem
I had a three boot system, OSX, Linux Mint and Zorin. My version of OSX 10.6 was dying with many sites refusing the old browsers on it so I thought I would try an Open Core upgrade.
The problem is I see the EFI boot for Zorin but when I select it nothing happens. Mint works fine. I need to re-install the boot thing without overwriting my data etc.
FWIW I hate the open core "Upgrade" iPhoto does not work, neither does iMovie, Find my Friend and a few more. What does work though is I have the latest version of MS Office and Slack, but the machine is very slow.
You could create a bootable USB Stick with Zorin and start that. Then choose the 'Try Zorin' Mode and use the Program Boot Repair. That is - like the Name says - for repairing the Boot Stuff.
Thanks that is exactly what I was looking for but...it didn't work. Here is the error message displayed:-
An error occurred during the repair.
Error: NVram is locked (Linuxmint not found in efibootmgr). Please report this message to boot.repair@gmail.com
A new file (/var/log/boot-repair/20241002_211140/Boot-Info_20241002_2111.txt) will open in your text viewer.
Any Ideas?
boot-repair-4ppa2056-zorin1 [20241002_2111]
============================= Boot Repair Summary ==============================
Default settings: ______________________________________________________________
The default repair of the Boot-Repair utility would reinstall the grub-efi of
sdb2,
using the following options: sdb1/boot/efi
Additional repair would be performed: unhide-bootmenu-10s use-standard-efi-file restore-efi-backups
Final advice in case of suggested repair: ______________________________________
Please do not forget to make your UEFI firmware boot on the Linux Mint 21.3 Virginia (21.3) entry (sdb1/efi//grub.efi (**** will be updated in the final message) file) !
You may also want to install Refind. (ubuntupreciseon2011imac - Community Help Wiki)
User settings: _________________________________________________________________
modprobe: FATAL: Module efivars not found in directory /lib/modules/6.8.0-40-generic
ls: cannot access '/sys/firmware/efi/vars': No such file or directory
Please backup your data before this operation.
The settings chosen by the user will reinstall the grub-efi of
sdb2,
Additional repair will be performed: unhide-bootmenu-10s use-standard-efi-file restore-efi-backups
rm /mnt/boot-sav/sda1/efi/Boot/bootx64.efi
mv /mnt/boot-sav/sda1/efi/Boot/bkpbootx64.efi /mnt/boot-sav/sda1/efi/Boot/bootx64.efi
rm /mnt/boot-sav/sdb1/efi/Boot/bootx64.efi
mv /mnt/boot-sav/sdb1/efi/Boot/bkpbootx64.efi /mnt/boot-sav/sdb1/efi/Boot/bootx64.efi
rm /mnt/boot-sav/sdb5/efi/Boot/bootx64.efi
mv /mnt/boot-sav/sdb5/efi/Boot/bkpbootx64.efi /mnt/boot-sav/sdb5/efi/Boot/bootx64.efi
Mount sdb1 on /mnt/boot-sav/sdb2/boot/efi
======================== Reinstall the grub-efi of sdb2 ========================
chroot /mnt/boot-sav/sdb2 grub-install --version
grub-install (GRUB) 2.06-2ubuntu7.2
chroot /mnt/boot-sav/sdb2 modprobe efivars
chroot /mnt/boot-sav/sdb2 efibootmgr -v before grub install
EFI variables are not supported on this system.
chroot /mnt/boot-sav/sdb2 uname -r
6.8.0-40-generic
chroot /mnt/boot-sav/sdb2 grub-install --efi-directory=/boot/efi --target=x86_64-efi
Installing for x86_64-efi platform.
grub-install: warning: EFI variables cannot be set on this system.
grub-install: warning: You will have to complete the GRUB setup manually.
Installation finished. No error reported.
df /dev/sdb1
mv /mnt/boot-sav/sdb2/boot/efi/EFI/Boot/bootx64.efi /mnt/boot-sav/sdb2/boot/efi/EFI/Boot/bkpbootx64.efi
cp /mnt/boot-sav/sdb2/boot/efi/efi/ubuntu/grubx64.efi /mnt/boot-sav/sdb2/boot/efi/EFI/Boot/bootx64.efi
df /dev/sdb5
mv /mnt/boot-sav/sdb5/EFI/Boot/bootx64.efi /mnt/boot-sav/sdb5/EFI/Boot/bkpbootx64.efi
cp /mnt/boot-sav/sdb2/boot/efi/efi/ubuntu/grubx64.efi /mnt/boot-sav/sdb5/EFI/Boot/bootx64.efi
df /dev/sda1
mv /mnt/boot-sav/sda1/EFI/Boot/bootx64.efi /mnt/boot-sav/sda1/EFI/Boot/bkpbootx64.efi
cp /mnt/boot-sav/sdb2/boot/efi/efi/ubuntu/grubx64.efi /mnt/boot-sav/sda1/EFI/Boot/bootx64.efi
chroot /mnt/boot-sav/sdb2 efibootmgr -v after grub install
chroot /mnt/boot-sav/sdb2 update-grub
Sourcing file /etc/default/grub' Sourcing file /etc/default/grub.d/50_linuxmint.cfg'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.15.0-122-generic
Found initrd image: /boot/initrd.img-5.15.0-122-generic
Found linux image: /boot/vmlinuz-5.15.0-102-generic
Found initrd image: /boot/initrd.img-5.15.0-102-generic
Found linux image: /boot/vmlinuz-5.15.0-101-generic
Found initrd image: /boot/initrd.img-5.15.0-101-generic
Found linux image: /boot/vmlinuz-5.15.0-97-generic
Found initrd image: /boot/initrd.img-5.15.0-97-generic
Found linux image: /boot/vmlinuz-5.15.0-94-generic
Found initrd image: /boot/initrd.img-5.15.0-94-generic
Found linux image: /boot/vmlinuz-5.15.0-91-generic
Found initrd image: /boot/initrd.img-5.15.0-91-generic
Found linux image: /boot/vmlinuz-5.15.0-89-generic
Found initrd image: /boot/initrd.img-5.15.0-89-generic
Found linux image: /boot/vmlinuz-5.15.0-88-generic
Found initrd image: /boot/initrd.img-5.15.0-88-generic
Found linux image: /boot/vmlinuz-5.15.0-87-generic
Found initrd image: /boot/initrd.img-5.15.0-87-generic
Found linux image: /boot/vmlinuz-5.15.0-86-generic
Found initrd image: /boot/initrd.img-5.15.0-86-generic
Found linux image: /boot/vmlinuz-5.15.0-76-generic
Found initrd image: /boot/initrd.img-5.15.0-76-generic
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
Found Zorin OS 17.1 (17) on /dev/sdb4
Unhide GRUB boot menu in sdb2/boot/grub/grub.cfg
Locked-NVram detected.
============================ Boot Info After Repair ============================
=> No boot loader is installed in the MBR of /dev/sda.
=> No boot loader is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system:       vfat
Boot sector type:  Unknown
Boot sector info:  According to the info in the boot sector, sda1 starts
                   at sector 0. But according to the info from fdisk,
                   sda1 starts at sector 40.
Operating System:
Boot files:        /efi/BOOT/bkpbootx64.efi /efi/BOOT/bootx64.efi
                   /efi/BOOT/fbx64.efi /efi/BOOT/mmx64.efi
                   /efi/OC/OpenCore.efi /efi/ubuntu/grubx64.efi
                   /efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
                   /efi/ubuntu/grub.cfg /efi/OC/Drivers/OpenCanopy.efi
                   /efi/OC/Drivers/OpenLinuxBoot.efi
                   /efi/OC/Drivers/OpenRuntime.efi
                   /efi/OC/Drivers/ResetNvramEntry.efi
                   /efi/OC/Tools/BootKicker.efi
                   /efi/OC/Tools/OpenShell.efi
sda2: __________________________________________________________________________
File system:       apfs
Boot sector info:
Mounting failed:   mount: /mnt/BootInfo/sda2: unknown filesystem type 'apfs'.
sdb1: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
                   /efi/ubuntu/grubx64.efi /efi/ubuntu/mmx64.efi
                   /efi/ubuntu/shimx64.efi /efi/ubuntu/grub.cfg
sdb2: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Linux Mint 21.3
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
sdb3: __________________________________________________________________________
File system:       hfsplus
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:
sdb4: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Zorin OS 17.1
sdb5: __________________________________________________________________________
File system:       vfat
Operating System:
                   /efi/ubuntu/grub/grub.cfg
sdb6: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sdc: ___________________________________________________________________________
File system:       iso9660
Boot sector info:
Mounting failed:   mount: /mnt/BootInfo/FD/sdc: /dev/sdc already mounted or mount point busy.
================================ 2 OS detected =================================
OS#1: Linux Mint 21.3 Virginia (21.3) on sdb2
OS#2: Zorin OS 17.1 (17) on sdb4
================================ Host/Hardware =================================
CPU architecture: 64-bit
Video: Whistler [Radeon HD 6730M/6770M/7690M XT] 2nd Generation Core Processor Family Integrated Graphics Controller from Advanced Micro Devices, Inc. [AMD/ATI] Intel Corporation
Live-session OS is Zorin 64-bit (Zorin OS 17.2, jammy, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: 87.0.0.0.0(0.1) from Apple Inc.
The firmware is EFI-compatible, and is set in EFI-mode for this live-session.
SecureBoot disabled - This system doesn't support Secure Boot.
BootCurrent: 0000
Timeout: 5 seconds
BootOrder: 0005,0004,0080,0000,0003,0002,0001
Boot0000* ubuntu HD(1,GPT,fc8151c5-4ff2-46d1-81b9-b64f53839c50,0x28,0x64000)/File(\EFI\ubuntu\shimx64.efi)
Boot0001* rEFInd Boot Manager HD(1,GPT,d8e96c6b-5d49-472f-a9fa-515412ef0ea6,0x4ab86cb8,0x22f3f7)/File(\EFI\refind\refind_x64.efi)
Boot0002* elementary OS 7 Horus HD(1,GPT,a768b32c-d165-4f0b-8513-3ff9e29ede6c,0x1000,0x838f7)/File(\EFI\ubuntu\shimx64.efi)
Boot0003* elementary OS 7 Horus HD(5,GPT,b09277de-0eb5-444a-bff8-9c8d23d4a3ba,0x739c9800,0x1d7800)/File(\EFI\ubuntu\shimx64.efi)
Boot0004* ubuntu HD(1,GPT,80218068-1f60-48d2-9e4f-948db45f512f,0x800,0x100000)/File(\EFI\ubuntu\shimx64.efi)
Boot0005* OpenCore PciRoot(0x0)/Pci(0x1f,0x2)/Sata(0,0,0)/HD(1,GPT,fc8151c5-4ff2-46d1-81b9-b64f53839c50,0x28,0x64000)/File(EFI\OC\OpenCore.efi)
Boot0080* OpenCore PciRoot(0x0)/Pci(0x1a,0x7)/USB(0,0)/USB(2,0)/HD(1,GPT,3f408aee-0d1a-4a58-bc2a-6346bebfe871,0x28,0x64000)/File(\boot.efi)
Boot0081* Mac OS X PciRoot(0x0)/Pci(0x1f,0x2)/Sata(0,0,0)/HD(2,GPT,6b164c23-9660-448e-83fe-3f393e23217c,0x64028,0x7456ce40)
BootFFFF* PciRoot(0x0)/Pci(0x1f,0x2)/Sata(0,0,0)/HD(1,GPT,d8e96c6b-5d49-472f-a9fa-515412ef0ea6,0x4ab86cb8,0x22f3f7)/File(\EFI\BOOT\BOOTX64.efi)
64349b3622c65f495a99dbf6102496e3 sda1/BOOT/bkpbootx64.efi
a1da253696a304dce6b4668b70151c0e sda1/BOOT/bootx64.efi
1d43d986c265d8c455d020e4a1f28c52 sda1/BOOT/fbx64.efi
1d260ff1255f189ab621209796ee2fed sda1/BOOT/mmx64.efi
a8f91e30bfb49298b7439d6eb99ce17a sda1/OC/OpenCore.efi
a1da253696a304dce6b4668b70151c0e sda1/ubuntu/grubx64.efi
1d260ff1255f189ab621209796ee2fed sda1/ubuntu/mmx64.efi
07e25dcaf57c776875f78fa36827c58e sda1/ubuntu/shimx64.efi
04cf2b974cb49cdb913fe64b8dd7d1f7 sda1/OC/Drivers/OpenCanopy.efi
23d425ee2c48e08bd9378b0c69ba234b sda1/OC/Drivers/OpenLinuxBoot.efi
956aca2d3df4b3d4c16c5a11fbef3f8d sda1/OC/Drivers/OpenRuntime.efi
7b648c26a9543667c962823dafd13669 sda1/OC/Drivers/ResetNvramEntry.efi
0414c00ee50afd5d8185931067ff0250 sda1/OC/Tools/BootKicker.efi
502da15936fd3a6b65a80c5265e125d0 sda1/OC/Tools/OpenShell.efi
5783b82bc1dd7d612ca0447b737b35df sda1/APPLE/EXTENSIONS/Firmware.scap
07e25dcaf57c776875f78fa36827c58e sdb1/BOOT/bkpbootx64.efi
07e25dcaf57c776875f78fa36827c58e sdb1/BOOT/bootx64.efi
1d43d986c265d8c455d020e4a1f28c52 sdb1/BOOT/fbx64.efi
1d260ff1255f189ab621209796ee2fed sdb1/BOOT/mmx64.efi
a1da253696a304dce6b4668b70151c0e sdb1/ubuntu/grubx64.efi
1d260ff1255f189ab621209796ee2fed sdb1/ubuntu/mmx64.efi
07e25dcaf57c776875f78fa36827c58e sdb1/ubuntu/shimx64.efi
728124f6ec8e22fbdbe7034812c81b95 sdb5/BOOT/bkpbootx64.efi
a1da253696a304dce6b4668b70151c0e sdb5/BOOT/bootx64.efi
c152ec201c37b6e97bbc2207e49d1271 sdb5/BOOT/fbx64.efi
fdafb5eece6caeccb788c946a28e6872 sdb5/BOOT/mmx64.efi
3795ef72a4ed0369ca44e711527904bf sdb5/ubuntu/grubx64.efi
fdafb5eece6caeccb788c946a28e6872 sdb5/ubuntu/mmx64.efi
728124f6ec8e22fbdbe7034812c81b95 sdb5/ubuntu/shimx64.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, no-os, no-wind, 40 sectors * 512 bytes
sdb : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sda2 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
sdb1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sdb2 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, farbios
sdb3 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
sdb4 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, farbios
sdb5 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
Partitions info (2/3): _________________________________________________________
sda1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sda2 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sdb1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sdb2 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sdb3 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sdb4 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sdb5 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
sda1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
sda2 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
sdb1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb
sdb2 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sdb
sdb3 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb
sdb4 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sdb
sdb5 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb
fdisk -l (filtered): ___________________________________________________________
Disk sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk identifier: 08E017DD-B07D-4BC1-B4DE-C0D0A7168049
Start End Sectors Size Type
sda1 40 409639 409600 200M EFI System
sda2 409640 1953525127 1953115488 931.3G Apple APFS
Disk sdb: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk identifier: 42F726D5-9254-4EA2-9447-4B05DFACE0D7
sdb1 2048 1050623 1048576 512M EFI System
sdb2 1050624 782301183 781250560 372.5G Linux filesystem
sdb3 782301184 1647053095 864751912 412.3G Apple HFS/HFS+
sdb4 1647316992 1939379491 292062500 139.3G Microsoft basic data
sdb5 1939642368 1941573631 1931264 943M EFI System
sdb6 1941835776 2000146430 58310655 27.8G Microsoft basic data
Disk sdc: 3.75 GiB, 4026531840 bytes, 7864320 sectors
Disk identifier: 0x339ad900
Boot Start End Sectors Size Id Type
sdc1 * 0 6678143 6678144 3.2G 0 Empty
sdc2 572 10683 10112 4.9M ef EFI (FAT-12/16/32)
sdc3 6680576 7864319 1183744 578M 83 Linux
parted -lm (filtered): _________________________________________________________
sda:1000GB:scsi:512:512:gpt:ATA Samsung SSD 870:;
1:20.5kB:210MB:210MB:fat32:EFI System Partition:boot, esp;
2:210MB:1000GB:1000GB:::;
sdb:1024GB:scsi:512:4096:gpt:ATA Crucial_CT1024M5:;
1:1049kB:538MB:537MB:fat32:EFI System Partition:boot, esp;
2:538MB:401GB:400GB:ext4::;
3:401GB:843GB:443GB:hfs+::;
4:843GB:993GB:150GB:ext4::msftdata;
5:993GB:994GB:989MB:fat32:BOOT:boot, esp;
6:994GB:1024GB:29.9GB:linux-swap(v1)::msftdata;
sdc:4027MB:scsi:512:512:unknown:SMI USB DISK:;
Free space >10MiB: ______________________________________________________________
sdb: 804225MiB:804354MiB:129MiB
sdb: 946963MiB:947091MiB:128MiB
sdb: 948034MiB:948162MiB:128MiB
sdb: 976634MiB:976762MiB:128MiB
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda
├─sda1 vfat 67E3-17ED fc8151c5-4ff2-46d1-81b9-b64f53839c50 EFI EFI System Partition
└─sda2 apfs d870d072-7439-4f3c-b875-b93deb3e8115 bcee0b85-d736-405b-9899-62520e7856ca
sdb
├─sdb1 vfat EB10-191D 80218068-1f60-48d2-9e4f-948db45f512f EFI System Partition
├─sdb2 ext4 b5b95b3e-3830-4819-8d49-210d30c37627 a7351e82-9c7a-4a28-9685-c6d0de5cf30b
├─sdb3 hfsplus a00e90c3-9261-308f-bb7a-720379fbef2a 5d9f3052-d002-4c0a-a005-e3998881a56c MacintoshSD2
├─sdb4 ext4 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1 27f0208c-190a-4426-b9f3-3117115a5ba4
├─sdb5 vfat 7E65-15EA b09277de-0eb5-444a-bff8-9c8d23d4a3ba BOOT BOOT
└─sdb6 swap 9709ceba-cf1f-451d-b8d9-3222fc559085 aa7ebc78-0fe7-44df-bff2-bafb1f8922c6
sdc iso9660 2024-09-18-12-00-16-00 Zorin OS 17.2 Core 64bit
├─sdc1 iso9660 2024-09-18-12-00-16-00 339ad900-01 Zorin OS 17.2 Core 64bit
├─sdc2 vfat 0C83-C5F2 339ad900-02
└─sdc3 ext4 364971b6-de73-4643-9191-36a99f0a48cb 339ad900-03 writable
sdd
Mount points (filtered): _______________________________________________________
                                                           Avail Use% Mounted on
/dev/disk/by-label/writable[/install-logs-2024-10-02.0/crash] 502.8M 2% /var/crash
/dev/disk/by-label/writable[/install-logs-2024-10-02.0/log] 502.8M 2% /var/log
/dev/sda1 156.2M 21% /mnt/boot-sav/sda1
/dev/sdb1 504M 1% /mnt/boot-sav/sdb1
/dev/sdb2 235.2G 31% /mnt/boot-sav/sdb2
/dev/sdb3 264G 36% /mnt/boot-sav/sdb3
/dev/sdb4 113.8G 11% /mnt/boot-sav/sdb4
/dev/sdb5 922.1M 2% /mnt/boot-sav/sdb5
/dev/sdc1 0 100% /cdrom
Mount options (filtered): ______________________________________________________
===================== sda1/efi/ubuntu/grub.cfg (filtered) ======================
search.fs_uuid b5b95b3e-3830-4819-8d49-210d30c37627 root hd1,gpt2
set prefix=($root)'/boot/grub'
configfile $prefix/grub.cfg
===================== sdb1/efi/ubuntu/grub.cfg (filtered) ======================
====================== sdb2/boot/grub/grub.cfg (filtered)
Ubuntu b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-122-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-102-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-101-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-97-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-94-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-91-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-89-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-88-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-87-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-86-generic b5b95b3e-3830-4819-8d49-210d30c37627
Ubuntu, with Linux 5.15.0-76-generic b5b95b3e-3830-4819-8d49-210d30c37627
Zorin OS 17.1 (17) (on sdb4) 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1
Zorin (on sdb4) 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1
Zorin, with Linux 6.8.0-40-generic (on sdb4) 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1
Zorin, with Linux 6.5.0-35-generic (on sdb4) 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1
END /etc/grub.d/30_os-prober
END /etc/grub.d/30_uefi-firmware
========================== sdb2/etc/fstab (filtered)
/ was on /dev/sdb2 during installation
UUID=b5b95b3e-3830-4819-8d49-210d30c37627 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda1 during installation
/swapfile none swap sw 0 0
UUID=EB10-191D /boot/efi vfat defaults 0 1
======================= sdb2/etc/default/grub (filtered)
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian
GRUB_CMDLINE_LINUX=""
GRUB_DISABLE_OS_PROBER=false
==================== sdb2: Location of files loaded by Grub
       GiB - GB             File                                 Fragment(s)
        ?? = ??             boot/grub/grub.cfg                             1
207.660308838 = 222.973558784 boot/vmlinuz 1
99.449310303 = 106.782883840 boot/vmlinuz-5.15.0-101-generic 2
76.074344635 = 81.684205568 boot/vmlinuz-5.15.0-102-generic 2
207.660308838 = 222.973558784 boot/vmlinuz-5.15.0-122-generic 1
4.394893646 = 4.718981120 boot/vmlinuz-5.15.0-76-generic 2
272.449302673 = 292.540211200 boot/vmlinuz-5.15.0-86-generic 2
159.996173859 = 171.794583552 boot/vmlinuz-5.15.0-87-generic 1
131.118160248 = 140.787052544 boot/vmlinuz-5.15.0-88-generic 2
256.430660248 = 275.340324864 boot/vmlinuz-5.15.0-89-generic 2
2.285228729 = 2.453745664 boot/vmlinuz-5.15.0-91-generic 2
14.883785248 = 15.981342720 boot/vmlinuz-5.15.0-94-generic 2
72.933673859 = 78.311936000 boot/vmlinuz-5.15.0-97-generic 2
76.074344635 = 81.684205568 boot/vmlinuz.old 2
109.250972748 = 117.307338752 boot/initrd.img 5
269.875972748 = 289.777119232 boot/initrd.img-5.15.0-101-generic 7
215.863292694 = 231.781445632 boot/initrd.img-5.15.0-102-generic 10
109.250972748 = 117.307338752 boot/initrd.img-5.15.0-122-generic 5
49.875972748 = 53.553917952 boot/initrd.img-5.15.0-76-generic 7
368.360347748 = 395.523911680 boot/initrd.img-5.15.0-86-generic 9
300.761604309 = 322.940313600 boot/initrd.img-5.15.0-87-generic 9
254.750972748 = 273.536774144 boot/initrd.img-5.15.0-88-generic 7
174.495990753 = 187.363643392 boot/initrd.img-5.15.0-89-generic 5
109.211910248 = 117.265395712 boot/initrd.img-5.15.0-91-generic 9
131.493160248 = 141.189705728 boot/initrd.img-5.15.0-94-generic 10
336.285091400 = 361.083367424 boot/initrd.img-5.15.0-97-generic 8
215.863292694 = 231.781445632 boot/initrd.img.old 10
===================== sdb2: ls -l /etc/grub.d/ (filtered)
-rwxr-xr-x 1 root root 18683 Dec 18 2022 10_linux
-rwxr-xr-x 1 root root 43031 Dec 18 2022 10_linux_zfs
-rwxr-xr-x 1 root root 14387 Dec 18 2022 20_linux_xen
-rwxr-xr-x 1 root root 13369 Dec 18 2022 30_os-prober
-rwxr-xr-x 1 root root 1372 Dec 18 2022 30_uefi-firmware
-rwxr-xr-x 1 root root 700 Sep 20 2022 35_fwupd
-rwxr-xr-x 1 root root 214 Dec 18 2022 40_custom
-rwxr-xr-x 1 root root 215 Dec 18 2022 41_custom
====================== sdb4/boot/grub/grub.cfg (filtered) ======================
Zorin 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1
Zorin, with Linux 6.8.0-40-generic 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1
Zorin, with Linux 6.5.0-35-generic 6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1
Linux Mint 21.3 Virginia (21.3) (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-102-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-101-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-97-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-94-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-91-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-89-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-88-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-87-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-86-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-76-generic (on sdb2) b5b95b3e-3830-4819-8d49-210d30c37627
========================== sdb4/etc/fstab (filtered)
/ was on /dev/sdb4 during installation
UUID=6b6919e9-dee6-4d2f-8f2f-50e7d08c81a1 / ext4 errors=remount-ro 0 1
UUID=67E3-17ED /boot/efi vfat umask=0077 0 1
swap was on /dev/sdb6 during installation
UUID=9709ceba-cf1f-451d-b8d9-3222fc559085 none swap sw 0 0
======================= sdb4/etc/default/grub (filtered)
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_THEME=/usr/share/grub/themes/zorin/theme.txt
==================== sdb4: Location of files loaded by Grub
909.640647888 = 976.719208448 boot/grub/grub.cfg 1
893.994136810 = 959.918895104 boot/vmlinuz 2
840.960533142 = 902.974496768 boot/vmlinuz-6.5.0-35-generic 1
893.994136810 = 959.918895104 boot/vmlinuz-6.8.0-40-generic 2
840.960533142 = 902.974496768 boot/vmlinuz.old 1
797.751949310 = 856.579633152 boot/initrd.img 2
798.845699310 = 857.754038272 boot/initrd.img-6.5.0-35-generic 2
797.751949310 = 856.579633152 boot/initrd.img-6.8.0-40-generic 2
798.845699310 = 857.754038272 boot/initrd.img.old 2
===================== sdb4: ls -l /etc/grub.d/ (filtered)
-rwxr-xr-x 1 root root 18673 May 10 2023 10_linux
-rwxr-xr-x 1 root root 43021 May 10 2023 10_linux_zfs
-rwxr-xr-x 1 root root 14387 May 10 2023 20_linux_xen
-rwxr-xr-x 1 root root 13369 May 10 2023 30_os-prober
-rwxr-xr-x 1 root root 1372 May 10 2023 30_uefi-firmware
-rwxr-xr-x 1 root root 700 May 17 2023 35_fwupd
-rwxr-xr-x 1 root root 214 May 10 2023 40_custom
-rwxr-xr-x 1 root root 215 May 10 2023 41_custom
===================== sdb5/efi/ubuntu/grub.cfg (filtered)
search.fs_uuid 7E65-15EA root hd1,gpt5
set prefix=($root)'/EFI/ubuntu/grub'
=================== sdb5/efi/ubuntu/grub/grub.cfg (filtered)
elementary OS 7.1 Horus 5a0d53ff-fc95-49ff-85f3-bd4690875a39
elementary OS 7.1 Horus, with Linux 6.5.0-21-generic 5a0d53ff-fc95-49ff-85f3-bd4690875a39
elementary OS 7.1 Horus, with Linux 6.2.0-37-generic 5a0d53ff-fc95-49ff-85f3-bd4690875a39
elementary OS 7.1 Horus, with Linux 6.2.0-35-generic 5a0d53ff-fc95-49ff-85f3-bd4690875a39
elementary OS 7.1 Horus, with Linux 6.2.0-34-generic 5a0d53ff-fc95-49ff-85f3-bd4690875a39
Linux Mint 21.3 Virginia (21.3) (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-97-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-94-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-91-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-89-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-88-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-87-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-86-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Linux Mint 21.3 Cinnamon, with Linux 5.15.0-76-generic (on sdc2) b5b95b3e-3830-4819-8d49-210d30c37627
Hello. No comment on the Zorin part because I haven't been here long enough and don't dual boot anyway.
But on the OCLP, what did you upgrade to? Be sure to read the notes for issues with your model. For example Sequoia in my opinion from the notes is not quite there yet for my model, so I'm sticking with Sonoma until it gets sorted. They always work on it to resolve as many issues as they can. I don't need Sequoia yet anyway. You might try Ventura if your machine is very slow. Maybe even Monterrey, not sure if your browser would be grumbled at by sites on that though. I love OCLP Sonoma on my machine, but I might not notice if some things don't work, as I only use that machine for the latest version of Xcode, text editing and an occasional screen record.
Anyway hope you get your Mac sorted. They're beautiful machines. I don't suppose you could just run Mint or Zorin on the whole thing if the macOS goes south?
If I understand that right, Boot Repair doesn't find Your Linux Mint Boot Stuff. So, maybe it would be good to make that again, but with Linux Mint on the Stick. And it seems that it has Problems to set it up with EFI.
Okay, let's check something. When you are in Zorin or Linux Mint go to boot>efi>EFI and look what folders are inside. You will have to type in Your Password for this Path.
