Opening raw files with Gimp + Darktable
hi all,
i'm trying to use Gimp + Darktable but can manage to open a raw files with darktable plug-in in Gimp.
darktable plugin is installed but don't work.
i use ZorinOS package from the software store, no using flathub option that in fact don't install the darktable plugin in Gimp.
if i use rawtherapee, the plugin works fine i don't like it.
did someone have any idea to solve the problem.
thks
Yves
Install the Darktable team Repository:
sudo add-apt-repository ppa:ubuntuhandbook1/darktable
Update your sources, then install darktable application:
sudo apt update && sudo apt install darktable
thks it works fine !
A post was split to a new topic: Darktable app not working Zorin 16
