I tried to install zorin in my pc, first i tried to install it, it showed "out of range" blue coloured msg in my screen, its just black
However after some tweaks
Changing "quiet splash" to "quiet splash nomodeset" it worked and i installed, after installing it by setup, i restarted the pc, so again it shows that out of range probe, what can i do? Cannot see the desktop, nothing i can do helpp
Tap esc or tab when you boot starting when you see the motherboard or Zorin Splash Screen. This should show you the Grub Menu`
In the grub menu, select Advanced Options for Zorin
Then select Zorin on 5.15.0-75 (Recovery) The Kernel number on yours may be different - but what you are looking for is the (Recovery)
This will open the recovery menu. Arrown key down to the bottom to Drop to Root Prompt.
100% sure it installed by the setup, the problem started when i restart it, i installed it in another hard drive that is in the pc, now iam gonna install it in the hard drive that windows is in,
