I am currently attempting to resurrect my old laptop which contains a GT 425M with Nvidia Optimus. I connected my 2nd monitor to my laptop's HDMI port, but it isn't being detected at all.
My 2nd monitor keeps displaying 'No Signal', and
Try opening the nvidia server. If it is blank, and I'm almost 100% positive it's this, then you need to install a driver. You can try the late 400 series drivers or the 510.
In software and update settings, click the other tab and let it load. I would go with a lower number 500 series or the high number 400 series driver.
I'm not sure what driver that card is supported to. You can research that in the nvidia support page.
I used sudo apt remove --purge nvidia* to remove the modern Nvidia drivers which I mistakenly installed at boot. I just read that the modern drivers support cards from 2013.
Afterwards, I tried installing 340 but it ran into some errors, so it automatically installed bounced to the 3rd option, the open source drivers.
I rebooted and my laptop is currently showing, Oh no! Something has gone wrong. A problem has occurred and the system cannot recover. Please contact a system adminstrator.
Dang.. does it mean I have reinstall everything from scratch again?
This means that packages need to be configured- but you must access the desktop in order to do so and cannot access the desktop until it's done... heh...
Here is a Guide on how to fix that issue:
sudo apt install nvidia-390 didn't work, I tried sudo apt install nvidia-utils-390 and it was installed.
After rebooting, it got pass the Zorin logo, but the login screen didn't show up. It is a greyish looking screen throughout, it is not entirely pitch black.
There was some ACPI Error & ACPI BIOS Error messages which flashed very fast upon initial boot, not sure if it helps in troubleshooting.
Update: 2nd monitor displays now after running sudo apt install nvidia-driver-390. Thanks to all
Now to search for recommended alternative MS Office (Testing OnlyOffice) & PDF viewers..
I know you should really start a separate thread but I cannot recommend SoftMaker Office highly enough. My workflow increased tremendously from lockdown to retirement working from Home and was the only Office Suite compatible with MS Office 365/2019 used by Work colleagues. In terms of pdf viewers you already have it I believe in the form of Okular - but it is so much more than just a viewer. If you don't want to fork out for SoftMaker Office, they do a free one, Free Office which you have to provide an email to register it. I was lucky with SoftMaker Office giving me an offer I could not refuse in 2019 - 5 machine licence for SoftMaker Office 2018 for just £23.99 - they do versions for Windows, Mac and Linux. 5 machines could be 2 Windows, 2 Linux, 1 Mac or any combination or 5 Linux Machines!
SoftMaker Office is trying to get users to move to NX which is a monthly subscription which I won't move to - hope they are not going to ditch the one off payment versions!
SoftMaker Office:
FreeOffice:
All you need to know about Okular:
I still needed LibreOffice though in order to compress images in documents which SoftMaker Office does not currently have. Also for font spacing it uses percentages instead of pts (points) so if I was modifying text for a low-vision student who need fonts spaced 2 pts apart I would create a simple sentence in LibreOffice with said setting, save as a .docx file then open in TextMaker 2018/2021 and view the percentage setting so I knew what percentage setting for font spacing needed when future work requests came in.
