Hi, when trying to update packages, get the following errors:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
libnvidia-common-450 libnvidia-common-460
0 to upgrade, 0 to newly install, 0 to remove and 2 not to upgrade.
Using sudo apt install libnvidia-common-450 libnvidia-common-460 i get this:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libnvidia-common-450 : Conflicts: libnvidia-common
libnvidia-common-460 : Conflicts: libnvidia-common
E: Unable to correct problems, you have held broken packages.
I recognise these as probably something to do with the graphics drviers so don't want to go removing packages that may mean my display stops working
Any suggestions on the proper way to get these installed? Or is it nothing to worry about and should ignore.
Thanks.
