Hola, acabo de instalar zorin en mi net g5 de las que da el gobierno. y despues de eso tuve el error de Error: MINIMAL BASH-LIKE line editing is supported
despues de eso intente cambiar algunos parametros del bios para intentar acceder al sistema operativo. pero todo empeoró ya que ahora mi netbook no hace nada, literalmente no muestra nada la pantalla. conecte un monitor para ver si algo cambiaba y no fue asi. espero conseguir ayuda pronto
Translation:
Hi, i just installed zorin on my government net g5. after that i got the error Error: MINIMAL BASH-LIKE line editing is supported.
after that i tried to change some bios settings to try to access the operating system. but everything got worse because now my netbook does nothing, it literally shows nothing on the screen. i connected a monitor to see if something changed and it didn't. i hope i get help soon.
Translated with DeepL.com (free version)
Boot from your installation media and select Try Zorin. Once you are at the Desktop, go to Menu | System Tools | Boot Repair and run that. See if it gets you sorted.
Arranca desde tu medio de instalación y selecciona Try Zorin. Una vez en el Escritorio, ve a Menú | Herramientas del Sistema | Reparar Arranque y ejecútalo. A ver si se soluciona.
I don't want to even attempt a butchered translation lol anyone that can for me; please do - I have had very strange looks using translator apps to try communicating in other languages
In your BIOS settings - do you have, or see, any options for Secure Boot or possibly any RAID / AHCI settings for your disks? Both could be affecting the boot process. I'm not familiar with your computer but, these two usually are the most prominent with 'no boot device' related errors.
And - what make / model computer are you using?
Okay, I will try it for You.
@navid97 :
No quiero ni siquiera intentar una traducción chapucera, pero si alguien puede ayudarme, por favor, que lo haga. Me han mirado de forma muy extraña utilizando aplicaciones de traducción para intentar comunicarme en otros idiomas
En la configuración de la BIOS - ¿tiene, o ve, alguna opción para Secure Boot o posiblemente alguna configuración RAID / AHCI para sus discos? Ambos podrían estar afectando al proceso de arranque. No estoy familiarizado con su ordenador, pero, estos dos suelen ser los más prominentes con 'no hay dispositivo de arranque' errores relacionados.
¿Qué marca y modelo de ordenador utiliza?
Traducción realizada con la versión gratuita del traductor DeepL.com
