PC won't load BIOS after loading Zorin
I tried Windows 11 and I had to enable Intel Security TMP in BIOS, long story short Windows 11 was trash and I decided to revert back to 10, I disabled TMP and reinstalled system on my main drive. Because other drives were locked I decided to plug out my system drive,reenable TMP. Boot Zorin through flash drive and backup data before, disabling TMP and reformatting drives. I tried to boot Zorin through flash drive but It's stuck in infinite loading, even if I restart without a flash drive, it also blocks me from booting a BIOS. Guys please help
Did You checked in BIOS that TPM, Secure Boot and Fast Boot are turend off? How is Your Zorin Boot Stick formatted? Which Tool did You use to create the bootable Stick?
After trying everything and googling for hours, somehow chat gpt saved me, I've been able to acess bios throught this:
  • Power off your computer.
  • Disconnect the power cord and remove the battery (if it's a laptop).
  • Press and hold the power button for about 30 seconds to discharge any residual power.
  • Reconnect the power cord and battery.
    And after that I disabled Windows UEFI that was enabled by default then sucessfully booted Zorin, although I'm still thankfull for response.
