hey i bought a usb 3.1 pendrive it has support upto 130 mbps but it does'nt giving me half of it at starting of copying a almost 4gb file it gives approx 70 mbps but after few seconds it drop on 10 to 20 mbps
i don't have an idea but i tried to check all ports have same colour
and one more thing i discovered only in 1 port i am getting upto 50 to 60mbps speed in other i am getting just 10 to 20 mbps max to max max 30mbps and in that 1 port i am getting peak at 70mbps
Your computer has ports that are older technology than the thumbdrive that you purchased. While new usb standards require backward compatibility, the speeds are limited to the version of usb that accesses the drive. What that means is that two ports of your computer will be limited to usb2.0 speeds and one will be limited to usb3.0 speeds. Your computer doesn't support usb3.1. The drive will work, but not at the 3.1 speeds. There is no getting around the limitations of the hardware except by purchasing a computer with those new standards.
