When I open my desktop Plank is not visible .... I have to go into Main Menu and click on Plank to get it to open ....
Any idea's how to make it open on desktop start ??? .....
nano ~/.config/autostart/Plank.desktop
add and modify following;
[Desktop Entry]
Type=Application
Exec=plank
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
Name=Plank
But I'm not sure if Cinammon needs some specific lines, as this will work on Gnome.
Thanks Storm .... that appeared to work when I restarted .... Plank is now showing on desktop startup
We also have a convenient "Startup Applications" dialog. Just use the add button to give the name, description and command. The command to fill in is "plank".
P.S. - Plank has lots of good themes available on:
gnome-look.org.
