Please add auto tiling feature
Pleae add Pop-os like auto tiling feature in the next update
+1 for at least Windows like tiling. I tried the gTile extension but it mucked up my system.
You can install Pop_Shell into Zorin 16 Beta, I used this tutorial.
Though it is true that a default tilling would be nice (and less of a hassle).
Not bad. Need to get used to the shortcuts but nice.
I would love an integrated version of the pop shell tiling with customizable shortcuts
I can recommend Tiling Assistant, it pretty much replicates Windows 10's tiling
I automated the install of Pop-shell in a script I made, feel free to try this out if you're too lazy to do it yourself.
Using Magnet on the Mac and trying gTile on Zorin, I ended up getting Tiling Assistent (Tiling Assistant - GNOME Shell Extensions) based on your recommendation.
It is a lot easier to configure and mostly replicates the way Magnet works for me on the Mac. Thanks for the tip!
