I've had Zorin-OS 16 then Zorin Pro for six weeks after switching from Windows 10. For the most part, I've adjusted and learned as I've used it for work but I don't really have time to really explore its features, at least not yet.
One thing I haven't caught the hang of is using the clipboard. In W10, clipboard history was a standard feature. I used it for work dozens of times a day. When I look up how to find such a feature in Zorin, I've only been able to find apps that will do it.
Is there an onboard clipboard history in Zorin? If not, what app and build of he app do I install? I don't have the hang of installing apps from a downloaded file, yet. That is to say, I've only done it once, and can't recall how to command it. I need my time for my actual work.
I do miss the clipboard history and the point-and-click install in W10. It surprises me that such time-saving features are missing in Zorin Pro.
I do realize this is an extremely simple problem, but I've found with Zorin that it's the simplest things that usually cause the biggest snags. Everyone assumes they're already known and they're never a topic in support groups or on tutorials.
