Possible to auto-login for unattended remote access
I have Zorin 17.2 Core. I have a pc on my home network that I want to connect to remotely. I've learned to do that with share desktop.
Now for the tricky part. For unattended access, I'd like the computer to boot up without requiring a password (remember: home network=limited access). Or is there some way to trigger remote connection before needing to enter the password? That would be sweet.
I want to avoid having to physically access the computer every time it has to reboot.
I'm a newbie to Linux, so help me gently...
If i'm understanding right, you should just be able to go into your Settings -> Users and enable the Automatic Login under your account to have the user be logged in automatically:
Thank you.
I forgot to mention that I have done that. However, for some reason, I am still asked to log in when I reboot.
I also followed a suggestion to do the following:
sudo nano /etc/gdm3/custom.conf
remove the comment (#)
Since I didn't see a comment, I'm not sure what to do. Looks like the autologin should work...
Here is the content of my custom.conf:
Other thoughts?
What is with this Line:
Remove the # part from "enabling automatic login", save and reboot.
hmmm. Right there in front of my nose.
Brilliant!
Thank you for your help and gentle guidance.
IT WAS A SUCCESS!
I've moved this to General Help and marked @Ponce-De-Leon's answer as the solution.
