Is it possible to store default or alternate display configurations, so that, for example, every time I add my 2nd monitor, I could load that config and not need to reposition the screen and change the resolution, etc.
When you switch to XOrg (logout, then at loginscreen click on your profile then a cog wheal appears, there you choose "Zorin desktop on Xorg) you can use Xrandr (a terminal program) or Arandr (that is a gui for Xrandr) to configure multiple monitor settings.
