Hi. New on the forum.
Yesterday I installed Zorin OS 17.1 Core on my computer. No dual boot. The process completed successfully.
Upon first login I was prompted to install the software updates downloaded during the install procedure. While it was "processing triggers" I had a power outage. I remember somerhig about initramfs when the system switched off. The computer still boots normally, but I'm wondering how to recover the interrupted installation. Should I just run the software updater again? Can I expect any issues because the update didn't complete?
I'm not a linux expert, any help would be really appreciated. Thank you.
If you can physically connect to your router, boot into recovery mode. If you can't see GRUB menu during boot, press left Shift key. Use recovery mode. Start network, then drop to a root shell prompt then:
sudo dpkg --configure -a
Afterward don't select continue, shut down, then boot the machine.
Thank you. That was helpful.
