The other day i wanted to cancel a print job sent to my printer but I could not find a way to cancel it in Zorin. How do I do that? Is there an equivalent of a control panel in Zorin? Thanks.
Just click on the printer icon in your taskbar, it will give you options
I don't have a printer icon in the task bar. How do I get the printer icon in the task bar?
Open Settings, scroll down to the Printers section, you will see your printer with a thing saying "1 Job" (or more) click on it and then you can cancel jobs.
Right click the taskbar and go into your settings and add it back in.
Sorry, I don't use Gnome so I can't give you a step by step.
It looks like I was able to do a search and answer my own question. To cancel print jobs, go into the terminal and type lpq. This will list the print jobs in the queue. Then enter cancel -a. That will cancel all print jobs in the queue.
You can just do it from settings lol you don't need the terminal. but whatever works
