Printer issues? Please start here
Recent updates that apply to Zorin OS 18 are causing printer issues due to security hardening:
Because of this, some users may find their printer no longer seen by the system.
For those affected, please launch terminal with app menu or ctl+alt+t and run each command one after another:
Also as per this thread:
sudo mv /etc/cups/cupsd.conf /etc/cups/cupsd.conf-orig
sudo cp /usr/share/cups/cupsd.conf.default /etc/cups/cupsd.conf
sudo systemctl start cups
If that does not resolve, it, continue with:
sudo apt install --reinstall cups cups-browsed cups-core-drivers
sudo systemctl restart cups
  • if unsuccessful, please open a thread and report that you tried the steps from this thread.
Dec 05 2025
@Aravisian Thanks bro :+1:
Thank you @Aravisian , I also had this problem with HP Envy 4500. But strangely, my printer now appears twice, even though I only have one printer.
Both work. :face_with_peeking_eye:
Hi @Dexxa, This is because of Network Discovery. You need to disable it, then delete the "ghost" printer.
sudo systemctl stop cups-browsed
followed by
sudo systemctl disable cups-browsed
It's in the unofficial manual.
(I have yet to learn how to stop/disable on a non-systemd OS.)
