Printer Troubleshooter
So with my printer is running with zorin fine till now but today it seems like its print heads are clogged, back when I was on windows, I used to make a deep clean using IJ printer assistant tool but it seems it is not on linux, so what are my options here?
What Printer do You have?
Canon PIXMA G2010
Can't you do that via the LCD/Setup button on the printer?
You could try mtink but no guarantees:
Apparently canon do have some button combinations to perform the tasks we can do with that app. I needed to clean the print head which I got in the manual. thanks for your screenshot though, otherwise I had no idea such thing may exist.
