Printing to Brother MFC (CUPS) causes system to hang for about a minute
New Zorin user (17.3 Core, on ThinkPad L380), but have been using Linux for a year or so.
After a month, I love Zorin and everything working really well...except printing to my network Brother MFC.
I've installed the Brother Deb linux drivers, but every time I print (or even if I just make changes to settings > printers in Zorin) the system hangs completely for a minute or so, but then recovers. Seems to CUPS related?
Any advice on how to troubleshoot & resolve would be gratefully received.
Thanks!
So, how is Your Printer connected exactly? Is it connected to Your Router or to Your PC?
Both laptop and printer are connected to a network switch.
I used the same setup under Ubuntu 22 and 24 without issue before moving to Zorin.
Thanks for your help!
Okay. Could You connect the Printer directly without the Network Switch and check if it would run?
Tried with static IPs and a crossover network cable; same issue.
As well as previously working well with this system whilst running Ubuntu, the printer also works fine with various Chromebooks and a Windows 10 pc.
Not certain what to do now...thanks!
And does the Printer works when You connect it with a USB Cable to Your PC?
I have discovered that this system freezing/hanging when printing only happens after the Zorin laptop has been suspended; after a reboot, it continues to print fine & without hangs/freezes, but if I suspend it and then log back in, the printer hanging happens without fail. Network or USB.
Does that help?
Hmm ... maybe when Your Laptop is suspended, some Files or a Service didn't get back.
It does seem like several recent threads are dealing with issues upon wake - as if the Wake function is not fully initializing everything.
A lot of this may narrow down to USB functionality and setting that to stay on may help mitigate some troubles:
echo 'on' | sudo tee /sys/bus/usb/devices/usb*/power/control
Thank you; will try and report back.
I made this change and hangs/freezes whilst printing after a suspend have improved a little, but not completely.
NickP
Thank you, but on balance, this hasn't really helped. Any other suggestions or checks that you can recommend that I can make? Thanks!
