Problem in update,what is the problem in update, err,hit,secure,
eid@eid-HP-Compaq-6005-Pro-SFF-PC:~$ sudo apt-get update
Hit:1 http://deb.fdmpkg.org bionic InRelease
Hit:2 http://packages.microsoft.com/repos/code stable InRelease
Hit:3 http://archive.ubuntu.com/ubuntu focal InRelease
Ign:4 http://ppa.launchpad.net/aacebedo/libi3ipc-glib/ubuntu focal InRelease
Hit:5 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:6 https://packages.microsoft.com/ubuntu/18.04/prod bionic InRelease
Hit:7 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:8 https://repo.protonvpn.com/debian stable InRelease
Hit:9 http://ppa.launchpad.net/blaze/main/ubuntu focal InRelease
Ign:10 http://apt.keepsolid.com/zorin focal InRelease
Hit:11 http://archive.ubuntu.com/ubuntu focal-security InRelease
Ign:12 https://repo.vivaldi.com/stable/deb stable InRelease
Ign:13 http://ppa.launchpad.net/daniel-marynicz/filemanager-actions/ubuntu focal InRelease
Hit:14 https://repo.vivaldi.com/stable/deb stable Release
Err:15 http://apt.keepsolid.com/zorin focal Release
  404  Not Found [IP: 144.217.71.199 80]
Hit:16 http://ppa.launchpad.net/ernstp/mesarc/ubuntu focal InRelease
Hit:17 http://ppa.launchpad.net/font-manager/staging/ubuntu focal InRelease
Hit:18 https://packages.zorinos.com/stable focal InRelease
Hit:19 http://ppa.launchpad.net/gerardpuig/ppa/ubuntu focal InRelease
Hit:20 http://ppa.launchpad.net/inkscape.dev/stable/ubuntu focal InRelease
Hit:21 https://packages.zorinos.com/patches focal InRelease
Hit:22 http://ppa.launchpad.net/kdenlive/kdenlive-stable/ubuntu focal InRelease
Ign:23 http://ppa.launchpad.net/kgilmer/regolith-stable/ubuntu focal InRelease
Hit:24 https://packages.zorinos.com/apps focal InRelease
Hit:25 http://ppa.launchpad.net/lutris-team/lutris/ubuntu focal InRelease
Hit:26 https://packages.zorinos.com/drivers focal InRelease
Hit:27 http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu focal InRelease
Ign:28 http://ppa.launchpad.net/oguzhaninan/stacer/ubuntu focal InRelease
Hit:29 http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu focal InRelease
Hit:30 http://ppa.launchpad.net/oranchelo/oranchelo-icon-theme/ubuntu focal InRelease
Hit:31 http://ppa.launchpad.net/radeon-profile/stable/ubuntu focal InRelease
Ign:32 http://ppa.launchpad.net/rojtberg/sensors-unity/ubuntu focal InRelease
Hit:33 http://ppa.launchpad.net/teejee2008/ppa/ubuntu focal InRelease
Hit:34 http://ppa.launchpad.net/ubuntuhandbook1/conkymanager2/ubuntu focal InRelease
Ign:35 http://ppa.launchpad.net/w-shackleton/droidpad/ubuntu focal InRelease
Hit:36 http://ppa.launchpad.net/xubuntu-dev/extras/ubuntu focal InRelease
Hit:37 http://ppa.launchpad.net/xuzhen666/dockbarx/ubuntu focal InRelease
Hit:38 http://ppa.launchpad.net/zorinos/apps/ubuntu focal InRelease
Hit:39 http://ppa.launchpad.net/zorinos/drivers/ubuntu focal InRelease
Hit:40 http://ppa.launchpad.net/zorinos/patches/ubuntu focal InRelease
Hit:42 http://ppa.launchpad.net/zorinos/stable/ubuntu focal InRelease
Err:43 http://ppa.launchpad.net/aacebedo/libi3ipc-glib/ubuntu focal Release
  404  Not Found [IP: 185.125.190.52 80]
Err:44 http://ppa.launchpad.net/daniel-marynicz/filemanager-actions/ubuntu focal Release
Err:45 http://ppa.launchpad.net/kgilmer/regolith-stable/ubuntu focal Release
Err:46 http://ppa.launchpad.net/oguzhaninan/stacer/ubuntu focal Release
Err:47 http://ppa.launchpad.net/rojtberg/sensors-unity/ubuntu focal Release
Err:48 http://ppa.launchpad.net/w-shackleton/droidpad/ubuntu focal Release
Err:49 https://repo.hotspotshield.com/deb/rel/all release InRelease
  Temporary failure resolving 'repo.hotspotshield.com'
Ign:50 https://ocean.surfshark.com/debian stretch InRelease
Err:51 https://ocean.surfshark.com/debian stretch Release
  Could not wait for server fd - select (11: Resource temporarily unavailable) [IP: 104.18.121.34 443]
Reading package lists... Done
E: The repository 'http://apt.keepsolid.com/zorin focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ppa.launchpad.net/aacebedo/libi3ipc-glib/ubuntu focal Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/daniel-marynicz/filemanager-actions/ubuntu focal Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/kgilmer/regolith-stable/ubuntu focal Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/oguzhaninan/stacer/ubuntu focal Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/rojtberg/sensors-unity/ubuntu focal Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/w-shackleton/droidpad/ubuntu focal Release' does not have a Release file.
E: The repository 'https://ocean.surfshark.com/debian stretch Release' does not have a Release file.
Whenever you add a repository, you need to check it first and make sure it is current and maintained.
Part of the trouble with the internet is that many people look up guides that are ten years old, then follow the instructions without ensuring that they apply to their system.
This can often be true on Windows OS too... You wouldn't have much luck using a guide for Windows XP on Windows 11.
The following repositories are ones that you have added that are not current or maintained:
Please remove them, then run sudo apt update. You can do a net search for the packages you are looking for in the FOCAL repositories.
Or, you can look for a package you need using pkgs.org and scroll down to Ubuntu 20.04.
good now I only get that error , do u recommend to remove that repo too (apt.keepsolid)
Note Down the Repositories giving Error in sudo apt update, then uncheck and remove them from Software & Updates. To Recheck Repositories giving Error run sudo apt update
Yep, it's not working, so remove it.
Thank u very much, that solved also the error of software updater with me. software updater is working very good now
