So I try to boot up, but then, I'm not sure how to navigate the menu.
It seems when i try to choose the linux iso, it doesn't do anything.
I close the laptop, plug the USB drive
then open it, press Esc, with F9.
Then Boot Manager Appear
White and Blue color
Boot Options Menu
OS boot Maanger (UEFI) - Windows Boot Manager (Sandisk)
Boot from EFI File
then I choose : Boot from EFI File
then File Explorer appear
No Volume Label
[bla-----]
Zorin OS 18
[bla-----]
I choose Zorin OS 18
then File Explorer
choose:
<.disk>
I choose , but nothing appear, then i choose , also same.
So which one to choose?
zenzen
October 23, 2025, 4:09pm
2
Hi, welcome to the forums!
Did you already complete the installation of Zorin OS, or is this what you see while you try to do so?
And just to clarify this:
Does this mean that you get to see the graphical interface, after login?
So, this happens when You try to start the USB stick with Zorin on it?
What tool did You use the create the bootable USB Stick? Are secure Boot and Fast Boot in BIOS disabled? Is Windows still installed? If yes: Should it stay or You want replace it? Is Fast Start-Up in Windows disabled? Does Your BIOS run in UEFI or Legacy Mode?
Could You make a Screenshot of this?
system
Closed
March 2, 2026, 4:26am
5
