Hello there, folks! In the last two days I've stumbled on a problem concerning connecting stuff with my main laptop via wifi, like Zorin Connect or Barrier. I use Barrier everyday to switch between my two machines and Zorin Connect to integrate my phone to the environment, but now it seems impossible. I tried booting with a previous kernel edition, but the problem wasn't fixed. Did someone ran into the same problem? Does anyone have any idea on how to fix it?
Do you have ethernet, or Wifi at all?
Can you please check in terminal:
sudo lshw -c network
I'm using Wifi. The laptop has a QCA9377 802.11ac Wireless Network Adapter
This should be well supported in the kernel. How is your wifi performance? Have you tested for packet loss or drop? Such as a speedtest or traceroute...
Not a single problem. The only problem is when trying to connect to other devices
I think we would be hard pressed to think both of the other devices were having wifi trouble.
Is your UFW Firewall enabled?
That was the problem. I had my my firewall on. I think that was the problem, 'cause now I turned it off and everything is back to normal.
Thanks for the help, @Aravisian !!
