Problem with bluetooth audio connection - Asus B650E-F
Hey,
I bought a new pc but I have a problem with my bluetooth connection on the Asus Rog Strix B650E-F motherboard. No bluetooth headset works properly.... There is a lot of crackling, interruptions and above all, when I move my head, the sound cuts out and comes back depending on the direction of the headphones towards the computer. I saw on Reddit that someone had the same problem as me, but the solution they came up with was to update their drivers on Windows. Do you have a solution for Zorin? (I'd also like to point out that I have the latest kernel (6.13.7)) but I've also tested the basic kernel and even installed Windows to test but I still have the same problem :/).
Thanks for your help :smiley:
The Reddit link: https://www.reddit.com/r/ASUSROG/comments/1b5mxgn/problem_with_bluetooth_audio_connection_asus/
Please open a terminal and enter:
hciconfig -a
and post back the results please.
Did You tried it with a BIOS Update for the Motherboard? Did You checkted if in the ''Additional Drivers'' Tab is maybe a Driver offered? And have You tried Pulse Audio Volume Control? It is a Tool to set up Audio Input and Output. You can install it with sudo apt install pavucontrol
Of course, here is the hci0 output: Type: Primary Bus: USB
BD address : 00:1A:7D:DA:71:15 ACL MTU : 310:10 SCO MTU : 64:8
UP RUNNING
RX bytes:708 acl:0 sco:0 events:51 errors:0
TX bytes:3174 acl:0 sco:0 commands:50 errors:0
Characteristics: 0xff 0xff 0x8f 0xfe 0xdb 0xff 0x5b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF PARK
Link mode: PERIPHERAL ACCEPT
Class: 0x6c0104
Service classes: Rendering, Capture, Audio, Telephony
Device class: Computer, Workstation
HCI version: 4.0 (0x6) Revision: 0x22bb
Version LMP: 4.0 (0x6) Subversion: 0x22bb
Manufacturer: Cambridge Silicon Radio Cambridge Silicon Radio (10)
hci1: Type: Primary Bus: USB
BD address: C8:A3:E8:81:59:58 ACL MTU: 1021:6 SCO MTU: 240:8
UP RUNNING
RX bytes:663141 acl:120 sco:0 events:93881 errors:0
TX bytes:78243207 acl:91714 sco:0 commands:2144 errors:0
Characteristics: 0xbf 0x3e 0x8d 0xfe 0xdb 0xff 0x7b 0x87
Link policy: RSWITCH SNIFF
Class: 0x6c0104
Device class: computer, office workstation
Version HCI: 5.2 (0xb) Revision: 0x2018
Version LMP: 5.2 (0xb) Subversion: 0x2311
Manufacturer: MediaTek, Inc : MediaTek, Inc (70)
Yes, I've updated the bios, I've looked in the additional drivers but there's nothing, and I've also tested pavucontrol but it didn't do much :confused:
Hmm ... maybe Your Bluetooth is not compatible. When You tested it in Windows: did You update the Drivers there and did it worked?
The other Thing: Maybe Your Bluetooth is broken. You wrote that You bought a new PC. So, You should have Warranty. You could ask where You bought it or on the ASUS Support directly. Maybe they have an Idea or eventually Linux Drivers.
Alright guys, I beg you, insult me :sob:. Actually, the Bluetooth works perfectly fine, I must have been drunk when I installed my motherboard. There were antennas in the box to pick up the Wi-Fi and Bluetooth, and I forgot to put them on :clown_face:. Now it works, lol.
Well, if you are going to beg... I would not want to be so rude as to leave you hanging...
At least, it was a simple Way to fix it.
This thread reminds me of a training course I once attended, Motorcycle Instructors Training Conference 2 in Warwickshire. We were given a set of questions to work through. If I had read all the questions first, the last one stated "Only answer questions 1 and 2!".
Here is what i was going to post:
