Hi everyone, I can't choose the correct resolution for the external monitor that is connected to my laptop, the highest resolution I can choose in the settings is 1920x1080, my monitor is 3440x1440 (21:9 aspect ratio), does Zorin support this resolution?
alright I've made it work through a ThinkPad usb-c usb-a dock, just had to install a DisplayLink driver that i was able to find easily. wasn't able to add a custom resolution using cvt and xrandr
I am sorry, I get in a hurry - I did not word that very well.
Some users have an Integrated card (Intel) in combination with Dedicated (AMD or Nvidia) card.
I am confident by your repetition that if you had a dedicated card, you would have said so.
If you run the above command, if it fails, please read through the output and look for modeset(0): HDMI max frequency
Or similar and relay what it says here...
While I understand you want that beautiful high resolution on your monitor, my screen size is 3840x2400 but after months of struggle I finally succumbed and just set my display to 1920x1080.
The reason is: when you set your display to that high resolution you will also need to scale your screen to 200%. It seems great, until you use a program that ignores scaling. You end up with impossibly small icons/menus and displays which renders those programs unusable unless you switch back to 1920x1080 every time you want to use one of those programs. (I tried every fix possible but nothing worked.)
In my experience it was nearly 30% off all the programs I use on linux have this issue.
