During system startup, when i have to type password to log in to system, external monitor work fine. When i log in, external monitor loses signal. This monitor is connect to docking station, and docking station is connect to laptop via USB-C. xrandr see this monitor connected. I must go to display settings, choose "the same image" or "one display" and back to "screen connected" then all works fine. This problem is always when i turn on laptop. If i reboot, everything is good.
Looks like it worked. I'll see if everything will be OK after turning off the laptop for a long time. Thanks <3.
Edit:
However, it turned out to be even worse. Now, apart from the fact that there is no image at the start on the external monitor, even xrandr does not detect it.
xrandr :
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
XWAYLAND0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 119.93*+
1440x1080 119.92
1400x1050 119.90
1280x1024 119.83
1280x960 119.89
1152x864 119.77
1024x768 119.80
800x600 119.85
640x480 119.52
320x240 117.34
1680x1050 119.89
1440x900 119.94
1280x800 119.85
720x480 119.65
640x400 119.64
320x200 117.55
1600x900 119.95
1368x768 119.83
1280x720 119.86
1024x576 119.85
864x486 119.69
720x400 119.54
640x350 119.24
