sulthan
1
I am sharing my expereince so that this could help others.
I use R program and when I try to install a package it says curl is not available.
But when you try install it in terminal usinig
sudo apt install curl
You see a output that it is already installed. So, here is the solution
sulthan
2
The solution is use the following command in terminal
sudo apt-get install libcurl4-openssl-dev
After this if you install a package he package will install without any problem.
system
Closed
3
