I installed zorion in several rooms in a school where I work, however, when I turn on the computer, the screen to select the user is on the television and not on the monitor (which is a big problem) in this case the numbering of the screens is 1 (the television, via HDMI) 2 (monitor, via VGA)
I need help to be able to put the login screen on the vga monitor to look good for teachers. Can someone help me?
In both Core or Lite (Incl. Education), in your Displays app, setting the monitor you want Login to appear on as the Primary should resolve this.
Thanks, but I still can't.
is it here (attached in the file)?
Because I didn't get it here, would you send me a picture of the screen.
I assume that the highlighted monitor is the one you want the login to display on? If so, it is indeed set to primary.
I also use more than one monitor and if at boot, the login is on a different monitor than the one I want, I just move the mouse cursor to the one that I do want it on and it automatically transfers there following the cursor.
