I have a problem with DX11 on Intel Mobile GM965/GL960, I can't find anywhere what to do about it
Hello,
Are you running wine or Windows? If you are running Windows you need to find a Windows forum, because this is a Linux forum.
If you are running wine in Linux, make sure to setup wine with winecfg and winetricks to set up directx11.
wine and idk i must to do
What are you trying to run on Zorin?
A game typical 3D
You might want to try Proton via Steam. You can add non-Steam games and run with the Proton on. Wine isn't geared towards gaming.
ok, I'll try it and get back to you
if this din't work
Make sure you use
sudo apt install steam
FLatpak can be tedious.
If it doesn't work. I would suggest getting the game either on Steam or GoG.
You can also try Lutris to set up games.
okay ![]()
thank u now the game is runig
nice : D
This issue appears when your running a wine/proton version that does not support dx11. I used wine-ge 8-26 (if i remember correctly) and that one does not boot dx11 and dx12 games.
As storm said install steam and use proton. If you use lutris you can download proton from there as well.
Try to update your graphic drivers or update your BIOS. Also check for any hardware issues associated with your device.
I did some research and this card is over 18 years old, i highly doubt this card supports dx11 or dx12
