Hi! I have recently installed Zorin OS 15 Lite to revive an old computer that is dying, it works perfectly except for the app store, it doesn't load anything.
I need help
Thanks for reading
Can you please open a terminal with ctrl+alt+t keyboard shortcut.
Type or paste the following in one at a time:
sudo apt install --reinstall gnome-software
Reboot and test.
This error appears when entering the store after rebooting:
Terminal logs: JustPaste.it - Share Text & Images the Easy Way
Can you please run:
sudo apt install --reinstall ca-certificates
It worked =)
Thank you so much <3
