Hello. When i changing a Volume on Zorin 16 Pro.
My all headphones they "pierdzenie"(polish word "") when using change volume on youtube.
Where is the problem? I am using a usb dac not integrated.
Tube lamp also have this problems.
Where is the problem? Fail drivers. Fail iso?
Ok on Spotify i don't have this problem on youtube yes.
Ah Blazing Saddles, keep off the beans.
Does that bad sound just occur whilst you are in process of changing the volume, or is it all the time?
Are those "REAR" headphones ....
I am trying to learn some Polish from @Bourne's posting but so fat I am not very successful...
Actually Polish has a Latin root.
I could extrapolate a lot from (my half-cooked) French
Glad to know it was not an exhaustive effort.
I tried put english word here but i get warning this word is danger for this forum. When you find my problem with changing a volume from 0-100 then i heard that noise. Do I need install some drivers?
On webbrowser i heard that voice changing a volume but not in spotify.
After restart and start again Zorin this problem missing.
Problem is on firefox webbrowser. Checked on Vivaldi no problem. Weird.
Do you have any extensions or add-ons in Firefox. Have you tried turning them off to see if any cause the problem.
No extensions. I stopped experimental on Zorin don't have gnome docky dock or shell POP OS
Sometimes, you need to perform a reverse engineering @Bourn's comment to fully/partially understand what he wants to say. A good mental practice to keep us from going senile
Yes. Your question was if i have some extension on Firefox then I answear no extensions your question what you gived me. Then i put "." That means another sentence.
I saw a kernel is now 41 and my grub changed. Zorin changing a user settings.
