I'm having trouble connecting my Lenovo T400 to wi-fi. I'm running Zorin 15.3 32 bit. Really love it! If there's some way of connecting to wi-fi through settings or terminal, or if anyone could recommend a good external wireless adapter, I'd really appreciate it.
I tried the sudo command and got the following response:
RTNETLINK answers: Operation not possible due to RF-kill
I think the Linux Mint forum solution is a little beyond me at this point. When I tried it, I got a warning and a page of text I didn't understand. One day, I'll be able to understand more of it but for now, I think I'll go the route of a wireless extender with and ethernet port.
Thanks so much for your help! I really appreciate it.
Thanks, I will do so in the future. I'm just getting used to terminal and want to make sure I understand the basics a bit more before messing around in there.
I don't think I know enough to follow those directions. I'm not sure of where to place breaks or how to tell if the commands are wraparound or not, or whether a block of commands should be issued in a chain or all at one go.
I need to learn a few more basics and will work with an external solution in the meantime. I'll bookmark the above passage and see if I can make more sense of it in a few months.
Often, you can copy and paste (right click or... In terminal, the keyboard shortcuts ctrl+v and ctrl+c are replaced with ctrl+shift+v and ctrl+shift+c) and avoid spacing concerns.
Terminal commands do wrap around.
If you see a block of commands, then enter each line one at a time.
If a USB Wifi Adapter works, that is a perfectly viable solution, too.
I found out the solution...the wireless was hard blocked, not soft blocked. All I had to do was turn on the wi-fi toggle switch on the front of my computer!
