Hi. I'm stuck here for about half an hour. Is it normal?
Hi,
- Make sure that secure and fast boot is disable in BIOS.
- Do not choose "Download updates while installing Zorin.
I solved it by restarting everything and putting the BIOS into EIFI. One question: the touchpad seems to be slower. Any solution? I tried through settings but nothing
What device is your touchpad?
Example: "Elantech"
Where can I check it?
Doesn't matter. I restarted the pc and now the trackpad works very well!
