Problems installing RustDesk
I have installed Zorin OS on an hp ProBook 4330s with a Core i3-2350M and 8 GB RAM. I want to use RustDesk, so I downloaded the 64 bit Ubuntu .deb file. Accepting the suggested installation program gave no result. A search led to a suggestion to reboot. This made the installation program start, only to stop again with a message saying Failed installing file: not supported. Any suggestions why this happened, and how I can fix it?
What Installation Program was suggested?
Did You tried it with Gdebi to install?
After som restarts Gdebi managed to install RustDesk.
Marked the Solution.
