Hi, All. I know this has been posted about before, but I've scoured many of the previous posts on this subject, and none of the solutions seem to work for me.
I've tried both installing WINE as outlined on winehq.org and installing the Zorin Windows App Installer, but neither work. I am always met with a message saying I have unmet dependencies
. I keep trying to back track and install those dependencies, but it still doesn't work. I think one of the problems is that sudo apt install libc6
says that I have libc6 version 2.31 installed, and it doesn't see an updated version to install, and WINE keeps asking for libc6 version >=2.34.
Any help you can provide would be greatly appreciated.
I am single booting Zorin 16 Core natively/locally.
Here is the output from inxi -Faz
System:
Kernel: 5.13.0-27-generic x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13.0-27-generic
root=UUID=aa1a6b0b-f887-4d25-8ec9-2447635b4855 ro quiet splash
vt.handoff=7
Desktop: Gnome 3.38.4 wm: gnome-shell dm: GDM3 3.38.2.1
Distro: Zorin OS 16 base: Ubuntu 20.04 LTS Focal
Machine:
Type: Laptop System: Microsoft product: Surface Laptop 3
v: 124I:00036T:000M:0300000D:0B:07F:1C:05P:48S:01E:0Y:0K:0U:02
serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Microsoft model: Surface Laptop 3 serial: <filter> UEFI: Microsoft
v: 9.106.140 date: 04/30/2021
Battery:
ID-1: BAT1 charge: 40.1 Wh condition: 40.1/45.8 Wh (88%) volts: 8.5/7.6
model: SMP M1087273 type: Li-ion serial: <filter> status: Full cycles: 341
CPU:
Topology: Quad Core model: Intel Core i5-1035G7 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6
L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 23961
Speed: 1232 MHz min/max: 400/3700 MHz Core speeds (MHz): 1: 1214 2: 1300
3: 1300 4: 1170 5: 1206 6: 1265 7: 1281 8: 1225
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel Iris Plus Graphics G7 vendor: Microsoft driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:8a52
Display: x11 server: X.Org 1.20.13 driver: i915 compositor: gnome-shell
resolution: 2256x1504~60Hz
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
v: 4.6 Mesa 21.3.4 - kisak-mesa PPA direct render: Yes
Audio:
Device-1: Intel Smart Sound Audio driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:34c8
Sound Server: ALSA v: k5.13.0-27-generic
Network:
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3 chip ID: 8086:34f0
IF: wlp0s20f3 state: up mac: <filter>
Drives:
Local Storage: total: 119.24 GiB used: 34.21 GiB (28.7%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM128GDGTNG-87A0A
size: 119.24 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 80041C00 scheme: GPT
Partition:
ID-1: / raw size: 118.74 GiB size: 116.38 GiB (98.01%)
used: 34.21 GiB (29.4%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 317 Uptime: 7h 02m Memory: 7.36 GiB used: 3.15 GiB (42.8%)
Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Shell: bash
v: 5.0.17 running in: gnome-terminal inxi: 3.0.38
