Problems regarding voice echoing issue in youtube
I am facing this issue since 2 days like whenever i am watching a video on youtube after 2 mins the voice starts echoing and then comes back to normal.My specs are.Also i am facing this issue while after having some tweaks with ACI8880D wifi adapter.Pls help regarding this
What Browser do You use for YouToube? And is it/are they installed as Flatpak, Snap or .deb/APT Package? Do You have installed all the Codecs?
Is the Sound Issues with built-in Speakers or external? Did You checked it with other Speakers or Headphones to see if it behaves the same?
Hey my problem fixed after i update my system to 7.0.9 Liquorix kernel
Okay, good. That was a fast Solution, hahaha! You should oberserve it a bit to be sure it is fine now and maybe in a couple of Days report back. And then You could mark Your Post as Solution.
